tiepa
Oct 31, 2017Aspirant
Ethernet connection for second satellite
hello
is it possible to have the orbi router connected to the internet then the 1st satellite connected via the dedicated wifi signal then a third router/satellite connected to that satellite via a ethernet cable beaming out the same wifi ?
i have a satelite at the end of the house but the wifi cant get through the foil backed insulation into my garage but i have a ethernet cable already running from house to garage.
please help
thanks
paul
Sort By
- Streak2Master
No not currently possible.
However the latest firmware does allow for daisy chain connectivity. So if you are able to place the last satellite close enough to the first satellite it may just get through.
- tiepaAspirantThanks for the reply
I will certainly try that .
Another question I don’t understand why you can’t have the router with internet in and out ports wireless connection to the satilite with internet ont ports cable connection to a 3rd unit ( a router model ) with internet in port . Is the internet in connection on the 3rd not the same as the first router ?
Sorry but that seems logical to me .
Kind regards
Tiepa- Streak2Master
Once your Orbi is properly set up, then every ethernet port is internet enabled. ie. you can connect any device to any port on the router or satellite.
It's just that you can't link Orbi devices via cable, they have to be sync'd via wireless.
