Bluffplace
Dec 20, 2018Aspirant
Ethernet Connections
I picked up an RBK23. On my FIOS cablemodem, I have 3 ethernet connections. I am trying to avoid adding a switch and do not want to put the RBK23 in AP mode. Can I still use the 3 ports on my cable...
Bluffplace
The cablemodem is a FIOS Quantum Gateway Model FiOS-G1100
Dec 20, 2018Guru - Experienced User
Ok, yes, this has a built in router.
Try option 2 first.
