Bluffplace
Dec 20, 2018Aspirant
Ethernet Connections
I picked up an RBK23. On my FIOS cablemodem, I have 3 ethernet connections. I am trying to avoid adding a switch and do not want to put the RBK23 in AP mode. Can I still use the 3 ports on my cable...
CrimpOn
Dec 20, 2018Guru - Experienced User
Maybe this is an appropriate time to ask why you do not want to put the Orbi in AP mode? Does Orbi have "better" router functions than the FIOS router? (People seem to complain incessantly about Orbi's shortcomings, and it appears that lots of people prefer to put their Orbi in AP mode.) Are Orbi's router capabilities enough better that you will eat the cost of an inexpensive gigabit (unmanaged) switch? (You can get a switch for under $20, and there are LOTS of choices for under $50.)
Page 40 of the FIOS manual describes how to turn off the WiFi radios on it, which means it would not interfere with the Orbi.
https://www.verizon.com/about/sites/default/files/fios-qgr-userguide140925.pdf
I learn something new from every question that people ask on the Forum, so I'd like to understand your situation.
michaelkenward
Dec 21, 2018Guru - Experienced User
Good question, but maybe they read this and saw a feature that they need:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
