Bluffplace
Dec 20, 2018Aspirant
Ethernet Connections
I picked up an RBK23. On my FIOS cablemodem, I have 3 ethernet connections. I am trying to avoid adding a switch and do not want to put the RBK23 in AP mode. Can I still use the 3 ports on my cable...
Dec 21, 2018Guru - Experienced User
Using the DMZ on the FIOS router, maybe he could use the Orbi in router mode and have the best of both worlds. However there is the AP mode option too.
- ekhalilDec 21, 2018Master
DMZ on the FIOS is almost equivalent to bridging/bypassing the ISP router so he will not be able to use the ISP router's functionality with this setting.
- FURRYe38Dec 21, 2018Guru - Experienced User
Yes I already know this. Reason why it's mentioned in my initial post.
