StanM
Nov 28, 2017Aspirant
Ethernet ports active when Orbi is set as Access Point?
My cable modem and router (separate devices) are located in the basement. Ethernet lines are run from the router to various rooms throughout the house. I would like to install the Orbi system upstair...
- Nov 28, 2017
Thanks for the quick reply! I already ordered the Orbi system and I'm considering which installation option is easiest while still providing good coverage. This helps alot. Thanks.
st_shaw
Nov 28, 2017Master
Yes and Yes.
However, a collection of wireless access points might be a better solution if you already have Ethernet wiring throughout the house. Something like the Netgear Insight.
- StanMNov 28, 2017Aspirant
- StanMNov 29, 2017Aspirant
A followup question, please: When connecting the Orbi base to the existing router do I use the Orbi WAN input or one of the Orbi ethernet ports?
- st_shawNov 29, 2017Master
You must connect Orbi to your router using the Yellow Internet port, not one of the LAN ports. Otherwise, Orbi will light up magenta and think there is no Internet connection.
Thanks st_shaw. I guess the Access Point setting takes care of shutting off the IP address generation from the Orbi and uses the router, correct?
