jasperx's avatar
jasperx
Tutor
Feb 13, 2019
Ethernet versus wireless when your wired system is stuck with a 10/100 switch
The system is configured with both satellites and the Router (in AP mode) connected to the ATT Pace Router.  It seems to be running great though one day I caught the Orbi Router glowing red.  I didn't have time to deal with it and the next day all was well.
I have read the comments in other strings that the Ethernet connection is ALWAYS superior to the wireless.  What I did not see in those pronouncements is whether the presence of a 10/100 switch between the Orbi units and the router would change this.  My house came with a GE Security system that has a 10/100 switch built into the panel.  GE abandoned the security business and sold out and it appears that a gigabit switch component was never created.  Upgrading that switch in the telco setup will be a PIA.  I had thought that resetting the Orbi units to wireless might give a speed boost.  Now I am less sure because of the several factors that cut speed in half multiple times.
Will the Orbi Wi Fi be faster than ethernet run through 10/100 equipment?  If so, how much?  If so, where are the instructions for swapping out the mode?
If the WiFi truely is ALWAYS slower, it looks like I am going to be building a fancy patch setup to make room for a gigabit switch as in this photo.
  • jasperx wrote:
    Pace Router (isp) to 10/100 switch > House Cat5e > Orbi Satellites is the setup.
    Internet comes into the house at gigabit plus speed.  First device it hits is a fast Pace Router.  Second device it hits is a 10/100 switch. From the 10/100 switch cat5e carries data to the three Orbi devices.
    My alternative setup is to connect Orbi router (AP) to the Pace directly. Then connect each Orbi sattellite via wifi back to the Orbi router.
    This is the question... is the ethernet backhaul ALWAYS faster than the wifi? Or does the presence of a 10/100 bottleneck in the form of a switch, make ethernet a slower option than the wifi?
    I think using a 10/100 switch will limit your network on all interfaces in this setup.
    If you have good radio conditions then the wifi backhaul can provide you with 1.7 Gbps interface. So yes, get rid of this switch and connect the ISP router directly to Orbi and use wireless backhaul from the router to the satellites if the Orbi nodes are within reasonable distance from each other.
    • ekhalil's avatar
      ekhalil
      Master
      When you talk about wired vs. wireless connectivity, to which interfaces do you refer to:
      1. Interface between Orbi and the ISP router?
      2. interface between Orbi router and satellites?
      3. interface between devices and Orbi network?
      • jasperx's avatar
        jasperx
        Tutor
