MLewisCT
Dec 08, 2025Aspirant
Even if I "hide" the 5ghz, and "forget" the SSID on my android phone
These steps will not work for me for some reason. Even if I "hide" the 5ghz, and "forget" the SSID on my android phone, when it then shows the available networks, it is still a 5ghz network. I also...
- Dec 09, 2025
MLewisCT wrote:
I think I can connect the access point, turn off the Orbi, and set up the access pont WiFi to the same SSID/PWD as the Orbi.
Does that sound like it would work?
You'll need a router. Though your ISP "modem" might be a gateway (router+modem).
A variation will work
- change the SSID on the Orbi
- set up the AP to use the original SSID/PWD
Then of course change the SSID back after the install.
Dec 08, 2025Guru - Experienced User
MLewisCT wrote:Is there anything else I can do aside from buying a dedicated 2.4ghz access point just o configure the stupid Mitsubishi app and my new mini-splits?
Do you mean the "Comfort" app?
That is running for me over my Orbi wifi. There were some challenges pairing it with the heat pumps (though this was a few years ago, so I was installing the earlier"Kumo Cloud"). I don't recall what we needed to do get it working, but I don't think I had to do anything special with 5 ghz.
Are you able to discover the Mitsubishi adapter via bluetooth?
