terrspin11
Aug 20, 2018Follower
EX73000 Wall Plug Compatible with Orbi?
I am looking to connect a few a/v items via a Bridge to my Orbi system. Will the Netgear EX7300 work in that environment? I am assuming yes.
I had a old Nighthawk router set to Bridge, but the connection was solid for a month, then stopped working (i think the router had issues regardless). I tried a Linksys re6500, but the connection is spotty.
So, just want to make sure the ex7300 would work. Thank you!
1 Reply
Possible. It would be best to get another RBS satellite to use with the Orbi for best compatibility and operation...
