michaelcdbarnes's avatar
Jan 12, 2021
Extend RBK53
Hi, I have an RBK53 and need to buy an additional satellite purely so my daughter can have Ethernet point in her study. I have going to buy another RBS50 but they don't seem to be available. How can I achieve what I need? thanks,
  • plemans's avatar
    Your system can also use:
    RBS20, RBW30 (no ethernet port), RBS40, RBS40V (smart speaker), RBS50, RBS50Y (outdoor), and the EX7500/7700/8000
    The RBS40V tends to be the cheapest option as you can usually find it on sale for around that $100
    • michaelcdbarnes's avatar
      michaelcdbarnes
      Hi, As I just need an ethernet port is there a smaller device I can purchase rather than a large satelitte? thanks
      • plemans's avatar
        You can look through the compatible models that I listed. thats what works with it
