Jagmonkey
Oct 16, 2016Follower
Extending Orbi
Can I use either my nighthawk AC5300 or AC2200 as satellites to extend Orbi? If so then how? I would rather use something I already have rather than shelling out another $250 on a satellite.
- Oct 16, 2016
No, you can't use any Netgear routers as a satellite on the Orbi system. It uses a dedicated backhaul signal between Orbi Router and Orbi Satellites only currently (firmware may add Mesh functionality in the future with hops between Satellites back to the router). I believe this backhaul signal is even setup differently than is normally used, so that further adds to why you can't use other Routers to simulate a satellite.
loomis1975
Oct 16, 2016Luminary
peteytesting
Oct 16, 2016Hero
loomis1975 wrote:I believe this backhaul signal is even setup differently than is normally used, so that further adds to why you can't use other Routers to simulate a satellite.
no smoke and mirrors stuff here as i believe they just use a different wps password , the syncing of the sat's is just based on wps and the channel runs in the middle or high 5 gig bandwidth
