wairds
May 31, 2025Tutor
Extending RBR50 + 2 RBS50 satellites
The setup works well within my house. However I have just installed an external WiFi attached camera attached to the house. The signal the camera receives is weak which I believe could be improved b...
- May 31, 2025
Yes. Any brand of WiFi Extender should work. One key is to create a unique WiFi SSID for the network created by the extender so that the camera will connect only to the extender and not accidentally connect to one of the Orbi units with a lower signal level.
If there is ever a power outage, the Orbi router will begin broadcasting a WiFi signal before any of the Orbi satellites and some WiFi devices may reboot (after the outage) and connect to the router before satellites with a stronger signal even begin broadcasting. Mobile devices appear to be programmed to continue searching for a stronger signal, and users have reported that some devices make a decision quickly and quit searching.
wairds
May 31, 2025Tutor
CrimpOn, many thanks for your prompt response and suggestions. What you suggest re a different ssid makes sense as I am aware the camera does search for the strongest signal and therefore giving it a different ssid ensures it connects to the extender. For confirmation, would EX6150 or EX6120 be suitable?
