wairds
May 31, 2025Tutor
Extending RBR50 + 2 RBS50 satellites
The setup works well within my house. However I have just installed an external WiFi attached camera attached to the house. The signal the camera receives is weak which I believe could be improved b...
- May 31, 2025
Yes. Any brand of WiFi Extender should work. One key is to create a unique WiFi SSID for the network created by the extender so that the camera will connect only to the extender and not accidentally connect to one of the Orbi units with a lower signal level.
If there is ever a power outage, the Orbi router will begin broadcasting a WiFi signal before any of the Orbi satellites and some WiFi devices may reboot (after the outage) and connect to the router before satellites with a stronger signal even begin broadcasting. Mobile devices appear to be programmed to continue searching for a stronger signal, and users have reported that some devices make a decision quickly and quit searching.
wairds
Dec 08, 2025Tutor
The problem I am now having is that the extender is flipping to the Orbi router which is further away instead of staying on the satellite which has a stronger signal. This is happening without any power outages or rebooting that I am aware of. As a consequence the attached camera has a poor connection.
Any reason as to why this may be happening?
When I reboot the extender it attaches back to the satellite.
