wairds
May 31, 2025Tutor
Extending RBR50 + 2 RBS50 satellites
The setup works well within my house. However I have just installed an external WiFi attached camera attached to the house. The signal the camera receives is weak which I believe could be improved b...
- May 31, 2025
Yes. Any brand of WiFi Extender should work. One key is to create a unique WiFi SSID for the network created by the extender so that the camera will connect only to the extender and not accidentally connect to one of the Orbi units with a lower signal level.
If there is ever a power outage, the Orbi router will begin broadcasting a WiFi signal before any of the Orbi satellites and some WiFi devices may reboot (after the outage) and connect to the router before satellites with a stronger signal even begin broadcasting. Mobile devices appear to be programmed to continue searching for a stronger signal, and users have reported that some devices make a decision quickly and quit searching.
CrimpOn
Dec 08, 2025Guru - Experienced User
The first question is, "does this affect performance?" i.e. the camera connects to the WiFi extender. Does the camera continue to stream video well enough? It may be that the WiFi signal strength at the extender location is not very different in terms of the router and satellite.
- wairdsDec 08, 2025Tutor
Thanks for your response. Yes, it does affect performance. The reason I noticed it was that the picture began to freeze. It is fine for a couple of days when attached to the satellite and then it attaches to the router and cause problems.
