hcch
Jul 11, 2020Aspirant
Extra satélite compatibles
Hi I wonder if I can use other kind of satellites besides the RBR20's for my RBK43.
I understand the difference with the big 50 satélite will be speed but I do not know if I can use it no matter if the big satellites goes downdrade on performance to work like the 20s.
and the other question will be if I can use the satellites that connect to the wall power outlets, but I can not remember the model numbers for those.
thanks in advance
You can use these:
rbs20
rbw30
rbs40
rbs40v
rbs50
rbs50y
they'll all work. The 50 series will function at the lower backhaul that the rbr40 uses.
You can use these:
rbs20
rbw30
rbs40
rbs40v
rbs50
rbs50y
