Julie23269's avatar
Julie23269
Follower
Jun 12, 2017
Factory Reset w/o Original Wifi Name and Password
Hi - I managed to lose the original wifi name and code that came with my Orbi, and now I need to return it to factory settings. Does anyone know how I can find ot what those codes are...?  Or is there some way to reset them...?  I suspect that without them I won't be able to logon to the Orbi network after doing a factory reset...and I'm afraid to try.  Any help would be appreciated!!
1 Reply
  • if you connect via ethernet after a factory reset it should just bring up the initial install page and you go from there
