DAC128
Aug 28, 2018Aspirant
failure to connect orbi to satillite
Purchased new on 8/22/2018. Need phone number for support.
Orbi Router can't find satellite,
DAC128
Aug 28, 2018Guru - Experienced User
What FW are you using on the router?
Was the rourter FW updated before the satellite?
Are you getting a pulsating WHITE led on top of the satellite after its ready?
DAC128
FW is 2.1.4.16
Router was not updated.
Satellite is pulsating WHITE.
Thanks for responding, do you know of a Netgrear support phone number?
