WiseSilverWolf
Oct 27, 2019Tutor
Feature Request?
Is it possible to submit a feature request to Netgear for the Netgear Orbi? I would love to see Pi-hole added as a feature for Netgear Orbi: https://pi-hole.net/ without having to buy an extra Rasp...
- Oct 27, 2019
Nice idea. I think that Orbi (and specially the new Orbi AX) has a powerful processor that will be possible to manage additional apps/plugins.
Please post your ideas here: https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
maxalmond
Nov 26, 2019Aspirant
I would love to be able to use the orbi routers as satellites in some scenarios. Specifically, I would like to use an extra router as an additional satellites with an Ethernet connection for wired backhauling.
In terms of hardware, this must be possible :)
Thank you
Thank you
Nov 27, 2019Guru - Experienced User
Chipset design and FW code design, limits the RBRs to work in Router or AP mode only. No satellite support.
Thank you
