Doug-48051
Jul 11, 2017Luminary
Firmware 1.12.0.18 update error?
I completed an online automatic update for new FW 1.12.0.18 But I have update failed status message. but Current version number did update on SAT? So how do I correct this so the information i...
- Jul 11, 2017
Hello Doug
You may have to do a manual update on the satellite or even resync the satellite with the base station.
DarrenM
raven_au
Jul 13, 2017Virtuoso
DarrenM wrote:Hello Doug
Which doesn't fix the problem.
Nether does a maunual re-install of the firmware, either from the sat itself or from manual update using the router page.
Also resetting the sat to factory defaults doesn't help.
However, I'm having this problem with an add-on sat, the sat from the RBK50 pack did update OK.
Ian
raven_au
And doing a full reset to factory defaults and manual re-configure doesn't help.
And why does the RBS40 still have the last version of the firmware for download on the Netgear support page yet the router finds this new version.
Ian
- DarrenMJul 14, 2017Sr. NETGEAR Moderator
Hello aynok
I responded to your other thread.
DarrenM
