Doug-48051
Jul 11, 2017Luminary
Firmware 1.12.0.18 update error?
I completed an online automatic update for new FW 1.12.0.18 But I have update failed status message. but Current version number did update on SAT? So how do I correct this so the information i...
- Jul 11, 2017
Hello Doug
You may have to do a manual update on the satellite or even resync the satellite with the base station.
DarrenM
DarrenM
Aug 04, 2017Sr. NETGEAR Moderator
Hello vtrysty
Are you having other issues with the unit besides it saying its not updated?
DarrenM
waltwagner
Aug 05, 2017Tutor
I also have the "Update failed" showing for my satellite (RBS50), despite factory resetting, manually RE-updating both router and sat (w/ 1.12.0.18), resyncing, you name it. No way to get rid of "update failed".
- waltwagnerAug 05, 2017Tutor...regarding your question about any other issues: yes, my other issue is constant internet disconnects. It'll be perfect for maybe 12-24 hours--then, poof, no internet. Usually happens when I'm asleep, or otherwise not using any devices.
