iain1248
Oct 03, 2018Follower
Firmware 2.2.1.120 release notes
My Orbi offered a firmware update to 2.2.1.120. Where can I find the release notes.
If I search Netgear.com, the lastest firmware show is 2.1.4.16 from April 2018.
FAIL
RocketSquirrel
Oct 03, 2018Luminary
I assume you meant 2.2.1.210, and I imagine the release notes are the same as ChristineT posted elsewhere for 2.2.1.204. The difference between 204 and 210 is probably a last minute bug fix or two.
Release notes:
- Includes bug fixes for stability and performance
- Fixes Ethernet backhaul bug
- Supports the Orbi Voice
- Supports the Orbi Outdoor in Europe
AmitR
Oct 03, 2018NETGEAR Employee Retired
For RBK50, here it is: https://kb.netgear.com/000060273/RBR50-RBS50-Firmware-Version-2-2-1-210
It's also available for other kits.
Orbi Product Management
- loomis1975Oct 03, 2018Luminary
Not finding it for RBS50Y or RBS40.
Nor the RBS40V for that matter, I do see a newer 2.2.1.62 for the RBS40V though, is that the newest one and the one to use?
I haven't seen a new firmware for the RBS50Y in a long time.
I would like confirmation of what firmware we should be running on the RBS50Y, RBS40, RBS40V to complement the RBS50 and RBR50 running 2.2.1.210.
- Blanca_OOct 07, 2018NETGEAR Employee Retired
Hi loomis1975,
Please see the latest firmware for the following devices:
RBS50Y : FW v2.2.1.204 (https://kb.netgear.com/000060276/RBS50Y-Firmware-Version-2-2-1-204)
RBS40 : FW v2.2.1.210 (https://kb.netgear.com/000060274/RBR40-RBS40-Firmware-Version-2-2-1-210)
RBS40V : FW v2.2.1.62 (https://kb.netgear.com/000060259/RBS40V-Firmware-Version-2-2-1-62)
These should work with your existing RBK50 Orbi system.
Blanca
Community Team
- colingwalkerOct 03, 2018Guide
Update worked fine from the link... Even updated my 2 x plugin RBW30
