freakievinnie
Oct 04, 2018Star
Firmware 2.2.1.210 and connection problems Skybell
Yesterday I manually updated the firmware (2.1.4.16) of my Orbi RBR50 and RBS50 to 2.2.1.210. All devices quickly connected except for my Skybell Trim Plus doorbell. So I reset the router and satelit...
- Oct 10, 2018
Thank you all for your imput/help. It took a lot of time and frustration but my Skybell is online now for almost 2 days.
Wbwell3
Oct 04, 2018Aspirant
I am having the same problem with Skybell model the OP has. I noticed it was flashing orange a couple of days ago but didn’t have time to mess with it, figured it just needed to be reset.
Yesterday my chime started buzzing, which was corrected by removing the skybell. Assume that was happening because skybell wasn’t sending a signal and got stuck on ‘press’.
Yesterday I spent hours trying to connect only to 2.4ghz, unplugged the downstairs satellite to force my phone to 2.4, reset the skybell like 5 times. Nothing works. Seriously sitting here contemplating going and getting a ring pro or just a dumb doorbell and being done with it.
Every other 2.4 ghz device works flawlessly, and even outside on a brick house I get 30-50 up and 15 or so down speeds.
Ptted
I’m having the same issue with my SkyBell Trim Plus. Thinking about just going to get a nest hello.
- seanrkelly71Oct 05, 2018Star
Hi not sure if this helps hoever I had similar issue with Ring Pro Video Door Bell. After a reset the 2.4Ghz channel was set to 11. I read that my door bell on works on ch10 or below so I switched to 10 manually and my service came back.
