freakievinnie
Oct 04, 2018Star
Firmware 2.2.1.210 and connection problems Skybell
Yesterday I manually updated the firmware (2.1.4.16) of my Orbi RBR50 and RBS50 to 2.2.1.210. All devices quickly connected except for my Skybell Trim Plus doorbell. So I reset the router and satelit...
- Oct 10, 2018
Thank you all for your imput/help. It took a lot of time and frustration but my Skybell is online now for almost 2 days.
freakievinnie
Oct 05, 2018Star
I use WPA2-PSK [AES]. I changed it to WPA-PSK [TKIP] + WPA2-PSK [AES]. Unfortunately no result
I tried the channel settings: standard/auto, 11, 10, 6 and 1. Also no result
Thanks for your help. I really think it's a bug in the new firmware.
- FURRYe38Oct 05, 2018Guru - Experienced User
As a last resort test, disable security on the Orbi router and see if the device sees and connect?
Does the Orbi have a WPA and TPIK only setting? IF not, set back to your normal setting.
Only thing I can recommend is to contact NG support and inform them about this that it was working before the udpate and now it's not.You can try to revert however the system may autoupdate again. You can try blocking it:
1) Go to Advanced, Security, Block Sites and add the following sites.
http.fw.updates1.netgear.com
downloads.netgear.com
Kept digging on this and learned the following:
TCP port 443 (HTTPS): http.fw.updates1.netgear.com
TCP port 21 (FTP): updates1.netgear.com
I believe those two are all that's necessary to block. Orbi tries HTTPS first, then FTP.I don't guarantee this works either.
- freakievinnieOct 06, 2018StarThanks for your help.- The Orbi does not have a WPA and TPIK only setting. The only settings are: none,
WPA2-PSK [AES] and WPA-PSK [TKIP] + WPA2-PSK [AES]
- I will try to block the system updates folowing 'your' rules.
- What is the easiest way to contact NG support?
- I will disable security on the Orbi router. I will test this later. I'll keep you informed.
- FURRYe38Oct 06, 2018Guru - Experienced User
Thanks for your help.- The Orbi does not have a WPA and TPIK only setting. The only settings are: none,WPA2-PSK [AES] and WPA-PSK [TKIP] + WPA2-PSK [AES]
