freakievinnie
Oct 04, 2018Star
Firmware 2.2.1.210 and connection problems Skybell
Yesterday I manually updated the firmware (2.1.4.16) of my Orbi RBR50 and RBS50 to 2.2.1.210. All devices quickly connected except for my Skybell Trim Plus doorbell. So I reset the router and satelit...
- Oct 10, 2018
Thank you all for your imput/help. It took a lot of time and frustration but my Skybell is online now for almost 2 days.
freakievinnie
Oct 06, 2018Star
Thanks for your help.
- The Orbi does not have a WPA and TPIK only setting. The only settings are: none,
WPA2-PSK [AES] and WPA-PSK [TKIP] + WPA2-PSK [AES]
- I will try to block the system updates folowing 'your' rules.
- What is the easiest way to contact NG support?
- I will disable security on the Orbi router. I will test this later. I'll keep you informed.
Oct 06, 2018Guru - Experienced User
freakievinnie wrote:
Thanks for your help.- The Orbi does not have a WPA and TPIK only setting. The only settings are: none,WPA2-PSK [AES] and WPA-PSK [TKIP] + WPA2-PSK [AES]
