freakievinnie
Oct 04, 2018Star
Firmware 2.2.1.210 and connection problems Skybell
Yesterday I manually updated the firmware (2.1.4.16) of my Orbi RBR50 and RBS50 to 2.2.1.210. All devices quickly connected except for my Skybell Trim Plus doorbell. So I reset the router and satelit...
- Oct 10, 2018
Thank you all for your imput/help. It took a lot of time and frustration but my Skybell is online now for almost 2 days.
freakievinnie
Oct 08, 2018Star
After a lot of test work, I have some additional information.
Immediately after the update to firmware 2.2.1.210, the Skybell is connected and works as it should. At the moment the connection between the Orbi router and the Skybell is interrupted for a moment, the Skybell will no longer be/come online.
Then I changed the password of my router and used only lower case (so no upper case letters or 'strange characters' like # @! etc) letters. The Skybell does not connect. Then I have changed my password into numbers only. This too has no result at all. Finally, I did not use a password and then the Skybell immediately connected to my Orbi.
So it looks like it is a password/security problem because the router no longer accepts the existing ‘Skybell password’.
Oct 08, 2018Guru - Experienced User
So when not using any PW ON the router you turned OFF WPA security all together?
Immediately after the update to firmware 2.2.1.210, the Skybell is connected and works as it should. At the moment the connection between the Orbi router and the Skybell is interrupted for a moment, the Skybell will no longer be/come online.@Then I changed the password of my router and used only lower case (so no upper case letters or 'strange characters' like # @! etc) letters. The Skybell does not connect. Then I have changed my password into numbers only. This too has no result at all. Finally, I did not use a password and then the Skybell immediately connected to my Orbi.
- freakievinnieOct 08, 2018Star
Yes, the Skybell connects immediately when I NOT using a password on the router (leave it blanc) and TURNED OFF (Security Options select 'None' ) WPA security.
- FURRYe38Oct 08, 2018Guru - Experienced User
Ok, thank you for confirming this. I remember asking you about a few post prior. Also you said trying the other modes didn't work either. Something is broke in WPA/WPA2 and SkyBell. This is something to bring up with NG support.
- Christian_ROct 08, 2018NETGEAR Employee Retired
Hello All,
If you're still having issues with Skybell and the latest Orbi FW, please send me a PM with your name, email, phone, and preferred contact time (including time zone).
~Christian
- tcaprioOct 08, 2018Initiate
It worked! SkyBell technical support just emailed me tonight with a fix that worked like a charm. The Skybell HD immediately connected back to my Orbi wifi network. See below:
Thank you for contacting SkyBell Technical Support.
Please follow the instructions below to get the SkyBell back online:
- Press your SkyBell button in and hold it for about a minute. The LED will flash (rapid green>red and green>blue>YELLOW).
- Once you see the LED flash YELLOW, please release the SkyBell button.
- Within a minute, your SkyBell will be flashing red and green.
Once it is flashing red and green, select 'Add a new SkyBell' in your app and follow the on-screen instructions to re-sync your device until after you have selected your network. When asked to input your password, please select the "Advanced" at the top.
When syncing, you will need to use the advanced options within the SkyBell Application and enter the information below.
It will ask for the following:
-Password: This will be your WiFi password
-Keep it at WPA2
-IP Address: (see gateway first) Use the first three numbers from your default gateway and 201 for your 4th number (e.g. if your gateway is 192.168.1.x, use 192.168.1.201)
-Subnet Mask: 255.255.255.0
-Gateway: Use the number that follows "Default Gateway/Router" for your router/extender that you are using to connect the device (e.g. 192.168.1.x or 10.0.0.x, etc)
-DNS: 8.8.8.8 - Ray1manOct 08, 2018Aspirant
Finnaly a soultion That worked for me .. skybell back online after a long weekend of tinkering .and frustration..
thank you
Ray
- FeroxJBOct 08, 2018AspirantSo it sounds like we are just assigning the skybell a static IP address?
- FURRYe38Oct 09, 2018Guru - Experienced User
Glad someone contacted Skybell to get more help and information on this. Glad this seems to be working for others as well. You should mark this post a resolved so other will see it and find this information.
Thanks for posting it.Enjoy. :smileywink:
-Keep it at WPA2
-DNS: 8.8.8.8 - Garyt16Oct 09, 2018AspirantI’m still having trouble probably I’m not tech savvy. I manually entered the listed numbers including the gateway/router address but it’s still failing...help please!! Called Netgear and was on the phone for over an hour and then got disconnected.
- Garyt16Oct 09, 2018AspirantThanks to Paul (Cool2562) who took the time to reach out and text/walk me through the fix using the SkyBell app! Really appreciate him going above and beyond!!!
If anyone uses the Total Connect 2.0 app to connect SkyBell, and is successful reconnecting, can you advise? Thanks! - LuisfoOct 10, 2018AspirantHello!
Im having the same problem!
Still not working, i entered the ip manually and keeps blinking green blue and then failed.
What else do i have to do?? What do you changed? I rhink im stuck in the same problem you were. - Parentof2maOct 11, 2018Aspirant
Boom -- The solution above worked. Thanks for sharing!
- LuisfoOct 11, 2018AspirantPlease Help!
I dont know what im doing wrong,
Attached its my info, can you help me with the correct configuration Numbers in my case?? Thanks! - tarxvfOct 11, 2018Guide
Its the IP address in your case, use the ones i have listed below
-Keep it at WPA2
-IP Address: (see gateway first) Use the first three numbers from your default gateway and 201 for your 4th number (e.g. if your gateway is 10) Use - 10.0.0.201
-Subnet Mask: 255.0.0.0
-Gateway: Use the number that follows "Default Gateway/Router" for your router/extender that you are using to connect the device: Use - 10.0.0.1
-DNS: 8.8.8.8 - cool2562Oct 11, 2018StarSubnet mask would be different if the default gateway is 10.0.0.1
Subnet - 255.0.0.0
Anyone having issues with SkyBell can message me and I can walk you through. - LuisfoOct 11, 2018AspirantFinally worked!
Thanks a lot!!! - cool2562Oct 11, 2018Star
If your Default Gateway is 192.168.1.1 use subnet 255.255.255.0 and IP address 192.168.1.201
If your Default Gateway is 10.0.0.1 use subnet 255.0.0.0 and IP address 10.0.0.201
Hope that helps people
- deeperBreaOct 17, 2018Aspirant
RBR20
Thank you, you saved me much heartache and frustration. My SkyBell HD is working now.
- FURRYe38Oct 18, 2018Guru - Experienced User
Enjoy. :smileywink:
deeperBrea wrote:
RBR20
- ericsteward2003Oct 20, 2018Aspirant
after upgradeing my firmware, my satellite (RBS50) won't connect. I tried almost everything on the web that doesn't seem to work .
I have the RBR50 Oribi .
ericsteward2003@ yahoo.com
EST
- nitingautamOct 20, 2018Aspirant
Worked all fine :) thank you for the tip.
- FURRYe38Oct 21, 2018Guru - Experienced User
Make a new post about this in the main Orbi forum please.
EST
- Jeyglo9809Nov 07, 2018AspirantI am having the same issue and I dont know how to tell what to put from the description for my ip address and Gateway part can someone help with exactly the numbers I need to put. THANK YOU... also that's the numbers for my router my actual Skybell connects to the Orbi satellite does that make a difference I believe the ip address for satellite is 10.0.0.6 does this sound correct so which do I use?
- Ray1manNov 07, 2018Aspirant
This is done through the SkyBell app. Use the 10.0.0.1. And the 8.8.8.8
Jeyglo9809 wrote:
I am having the same issue and I dont know how to tell what to put from the description for my ip address and Gateway part can someone help with exactly the numbers I need to put. THANK YOU... also that's the numbers for my router my actual Skybell connects to the Orbi satellite does that make a difference I believe the ip address for satellite is 10.0.0.6 does this sound correct so which do I use?Please follow the instructions below to get the SkyBell back online:
-Keep it at WPA2
-DNS: 8.8.8.8
