freakievinnie
Oct 04, 2018Star
Firmware 2.2.1.210 and connection problems Skybell
Yesterday I manually updated the firmware (2.1.4.16) of my Orbi RBR50 and RBS50 to 2.2.1.210. All devices quickly connected except for my Skybell Trim Plus doorbell. So I reset the router and satelit...
- Oct 10, 2018
Thank you all for your imput/help. It took a lot of time and frustration but my Skybell is online now for almost 2 days.
Christian_R
Oct 08, 2018NETGEAR Employee Retired
Hello All,
If you're still having issues with Skybell and the latest Orbi FW, please send me a PM with your name, email, phone, and preferred contact time (including time zone).
~Christian
tcaprio
Oct 08, 2018Initiate
It worked! SkyBell technical support just emailed me tonight with a fix that worked like a charm. The Skybell HD immediately connected back to my Orbi wifi network. See below:
Thank you for contacting SkyBell Technical Support.
Please follow the instructions below to get the SkyBell back online:
- Press your SkyBell button in and hold it for about a minute. The LED will flash (rapid green>red and green>blue>YELLOW).
- Once you see the LED flash YELLOW, please release the SkyBell button.
- Within a minute, your SkyBell will be flashing red and green.
Once it is flashing red and green, select 'Add a new SkyBell' in your app and follow the on-screen instructions to re-sync your device until after you have selected your network. When asked to input your password, please select the "Advanced" at the top.
When syncing, you will need to use the advanced options within the SkyBell Application and enter the information below.
It will ask for the following:
-Password: This will be your WiFi password
-Keep it at WPA2
-IP Address: (see gateway first) Use the first three numbers from your default gateway and 201 for your 4th number (e.g. if your gateway is 192.168.1.x, use 192.168.1.201)
-Subnet Mask: 255.255.255.0
-Gateway: Use the number that follows "Default Gateway/Router" for your router/extender that you are using to connect the device (e.g. 192.168.1.x or 10.0.0.x, etc)
-DNS: 8.8.8.8
- Ray1manOct 08, 2018Aspirant
Finnaly a soultion That worked for me .. skybell back online after a long weekend of tinkering .and frustration..
thank you
Ray
- FeroxJBOct 08, 2018AspirantSo it sounds like we are just assigning the skybell a static IP address?
- FURRYe38Oct 09, 2018Guru - Experienced User
Glad someone contacted Skybell to get more help and information on this. Glad this seems to be working for others as well. You should mark this post a resolved so other will see it and find this information.
Thanks for posting it.Enjoy. :smileywink:
-Keep it at WPA2
-DNS: 8.8.8.8 - Garyt16Oct 09, 2018AspirantI’m still having trouble probably I’m not tech savvy. I manually entered the listed numbers including the gateway/router address but it’s still failing...help please!! Called Netgear and was on the phone for over an hour and then got disconnected.
- Garyt16Oct 09, 2018AspirantThanks to Paul (Cool2562) who took the time to reach out and text/walk me through the fix using the SkyBell app! Really appreciate him going above and beyond!!!
If anyone uses the Total Connect 2.0 app to connect SkyBell, and is successful reconnecting, can you advise? Thanks! - LuisfoOct 10, 2018AspirantHello!
Im having the same problem!
Still not working, i entered the ip manually and keeps blinking green blue and then failed.
What else do i have to do?? What do you changed? I rhink im stuck in the same problem you were. - Parentof2maOct 11, 2018Aspirant
Boom -- The solution above worked. Thanks for sharing!
- LuisfoOct 11, 2018AspirantPlease Help!
I dont know what im doing wrong,
Attached its my info, can you help me with the correct configuration Numbers in my case?? Thanks! - tarxvfOct 11, 2018Guide
Its the IP address in your case, use the ones i have listed below
-Keep it at WPA2
-IP Address: (see gateway first) Use the first three numbers from your default gateway and 201 for your 4th number (e.g. if your gateway is 10) Use - 10.0.0.201
-Subnet Mask: 255.0.0.0
-Gateway: Use the number that follows "Default Gateway/Router" for your router/extender that you are using to connect the device: Use - 10.0.0.1
-DNS: 8.8.8.8 - cool2562Oct 11, 2018StarSubnet mask would be different if the default gateway is 10.0.0.1
Subnet - 255.0.0.0
Anyone having issues with SkyBell can message me and I can walk you through. - LuisfoOct 11, 2018AspirantFinally worked!
Thanks a lot!!! - cool2562Oct 11, 2018Star
If your Default Gateway is 192.168.1.1 use subnet 255.255.255.0 and IP address 192.168.1.201
If your Default Gateway is 10.0.0.1 use subnet 255.0.0.0 and IP address 10.0.0.201
Hope that helps people
- deeperBreaOct 17, 2018Aspirant
RBR20
Thank you, you saved me much heartache and frustration. My SkyBell HD is working now.
- FURRYe38Oct 18, 2018Guru - Experienced User
Enjoy. :smileywink:
deeperBrea wrote:
RBR20
- nitingautamOct 20, 2018Aspirant
Worked all fine :) thank you for the tip.
- FURRYe38Oct 21, 2018Guru - Experienced User
- Jeyglo9809Nov 07, 2018AspirantI am having the same issue and I dont know how to tell what to put from the description for my ip address and Gateway part can someone help with exactly the numbers I need to put. THANK YOU... also that's the numbers for my router my actual Skybell connects to the Orbi satellite does that make a difference I believe the ip address for satellite is 10.0.0.6 does this sound correct so which do I use?
- Ray1manNov 07, 2018Aspirant
This is done through the SkyBell app. Use the 10.0.0.1. And the 8.8.8.8
Jeyglo9809 wrote:
I am having the same issue and I dont know how to tell what to put from the description for my ip address and Gateway part can someone help with exactly the numbers I need to put. THANK YOU... also that's the numbers for my router my actual Skybell connects to the Orbi satellite does that make a difference I believe the ip address for satellite is 10.0.0.6 does this sound correct so which do I use?Please follow the instructions below to get the SkyBell back online:
-Keep it at WPA2
-DNS: 8.8.8.8 - Jeyglo9809Nov 07, 2018AspirantSo I filled in:
1. My password
2. Ip address (It sounds like the directions are saying to put in 10.0.0.201 is this correct?
3. Subnet mask 255.255.255.0
4. Gateway I'm not sure what to put based on the directions
5. Dns 8.8.8.8
My main questions are on point 2 and 4 what do I fill in... You wrote 8.8.8.8 but that's for the DNS not gateway or am I misunderstanding? - Ray1manNov 08, 2018Aspirant
These setting are found and used in setup on the skybell app.
Jeyglo9809 wrote:
So I filled in:
1. My password
5. Dns 8.8.8.8
My main questions are on point 2 and 4 what do I fill in... You wrote 8.8.8.8 but that's for the DNS not gateway or am I misunderstanding? - cool2562Nov 08, 2018Star
private message me and I can walk anyone through how to get it working. IP address varies per network.
- FCCinAZNov 12, 2018Aspirant
This solution works but unfortunately, every time my router reboots, I have to manually reconnect the Skybell HD including deleting the device, factory reset, etc. Anyone figure out how to have it connect automatically again or is this up to Netgear or Skybell?
- FURRYe38Nov 13, 2018Guru - Experienced User
Have you tried setting a static IP address ON the skybell device?
- FCCinAZNov 13, 2018AspirantYes, I reserved it through the admin screen. I’m not sure if my IP address for the satellite changes when there is a reboot. Can I reserve an ip for the satellite?
