freakievinnie
Oct 04, 2018Star
Firmware 2.2.1.210 and connection problems Skybell
Yesterday I manually updated the firmware (2.1.4.16) of my Orbi RBR50 and RBS50 to 2.2.1.210. All devices quickly connected except for my Skybell Trim Plus doorbell. So I reset the router and satelit...
- Oct 10, 2018
Thank you all for your imput/help. It took a lot of time and frustration but my Skybell is online now for almost 2 days.
Skalsky
Oct 27, 2018Tutor
I also had the same problem and was given the same fix -- it works. Word to the wise, remember what this manual fix is the next time the SkyBell app needs reloaded or you get a new phone. Hopefully, by that time they will play nicely with the Dynamic assigning of IP addresses on the ORBI router so we do not have to assign a static IP address. None of my other IP appliances fell off the internet with the ORBI firmware upgrade.
