freakievinnie
Oct 04, 2018Star
Firmware 2.2.1.210 and connection problems Skybell
Yesterday I manually updated the firmware (2.1.4.16) of my Orbi RBR50 and RBS50 to 2.2.1.210. All devices quickly connected except for my Skybell Trim Plus doorbell. So I reset the router and satelit...
- Oct 10, 2018
Thank you all for your imput/help. It took a lot of time and frustration but my Skybell is online now for almost 2 days.
cool2562
Nov 08, 2018Star
private message me and I can walk anyone through how to get it working. IP address varies per network.
FCCinAZ
Nov 13, 2018Aspirant
This solution works but unfortunately, every time my router reboots, I have to manually reconnect the Skybell HD including deleting the device, factory reset, etc. Anyone figure out how to have it connect automatically again or is this up to Netgear or Skybell?
- FURRYe38Nov 13, 2018Guru - Experienced User
Have you tried setting a static IP address ON the skybell device?
- FCCinAZNov 13, 2018AspirantYes, I reserved it through the admin screen. I’m not sure if my IP address for the satellite changes when there is a reboot. Can I reserve an ip for the satellite?
You can reserve an IP address for the satellite under Advanced Tab/Setup/Lan. Add a reservation here for the satellite.
