steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
DaytonaZ33
Oct 03, 2018Star
Did anything change regarding the status of the satellite backhaul? Previously I had always "Good" status, now after this update my status is stuck at "Poor" even after reboot. No furniture or anything in the house has been moved in months, now all of a sudden this is an issue.
- FURRYe38Oct 03, 2018Guru - Experienced User
Try a factory reset on the system and setup from scratch?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
- BullyterrierOct 03, 2018Star
Hmmm, mine have updated and now are wide open....192.168.1.1 requires no login, nowhere to set admin password - if i logout I'm still logged in. Will try factory reset in the morning to avoid alienating the family again tonight.
Did you look under Advanced Tab/Advanced settings/Admin?
- RedBatman89Oct 03, 2018GuideI had this too. I had to factory reset to fix it.
Oddly I noticed a few times on my attached devices that it will show my satellites ad being off. Though a refresh shows them back on. It feels like there is quite a few bugs so far. - WoodsideDadOct 12, 2018Aspirant
Have the same issue (though only on one satellite)
- FURRYe38Oct 12, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Try this as well:
