steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Bodini
Oct 03, 2018Aspirant
Updated through the app. Working as before. RBR50 / RBS50 with wired backhaul.
- madhatterDec 14, 2018Apprentice
so, does the wired backhaul work any better now?
- FURRYe38Dec 14, 2018Guru - Experienced User
Wired back haul has been working since v16.
Most of the issues are surrounding setup and use of managed switches, mainly IGMP protocols. If thats disabled, Orbi wired back haul works fine. Non managed switches are preferred. Also switches that have GREEN ethernet features also don't play well with Orbi. Sonos devices also wreak havoc on Orbi system too.
There is a process to set up up wired backhaul. Once it's up and running. it works well.
Been up and running since day one with ZERO issues:
- madhatterDec 15, 2018Apprentice
thanks for the info, I was unaware of any problems with switches. I have 5 unmanaged switches, and all but 1 have some sort of energy savings. I have never even thought about that since the switches just work. The way I have my setup right now is an R6300v1 with 1 LAN port in use going to switch#1. All of the other switches are fed from switch#1. So, if I get an Orbi, my plan would be to simply swap out the R6300v1 with the Orbi router, plug that switch#1 into the Orbi and continue working the way it is today.
If there's a problem with switches, what kind of problems would I see with the 35 devices I have connected into my switches?
