steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
xanderwong
Oct 04, 2018Tutor
RBK40, my satelite now refuses to connect to the router immediately after the update. Restarting the satelite and pressing the sync buttons seems useless. Everytime when there's a new firmware, it makes my life difficult.
Oct 04, 2018Guru - Experienced User
I would do that BullyTerrier did:
Manual download of the img files and manual update plus factory reset then setup from scratch. Use IE11 or FF browser to send the FW files.
- xanderwongOct 04, 2018Tutor
I have 16 different devices connected to Orbi, and if everytime the useless Netgear team decides to release a new firmware (which I cannot opt out or disable auto-update) and screws with my work, I am at their mercy. I am sick of this **bleep** every single time Netgear releases a firmware and things will go haywire.
With that aside, I really appreciate your advise FURRYe38, but I cannot even access the satelite (sorry not router) now through the ethernet cable. I am experienced in manually updating and doing the entire firmware update cycle, but this time, the satelite seems to be dead/bricked. Any advise?
- deestoOct 04, 2018Guide
Can't bloody downgrade it to .16 anymore! Everytime I have manually updated it to old FW, it automatically bumps it up :O :(
Also, please see my other threads in regards to having ANYTHING plugged in to its ethernet ports on start up/powering up. It will KILL all bandwidth as at least one of the units will think it is plugged in Wired mode, not 5G (I assume it is thinking that it is pairing up via Ethernet backhual mode?), but in reality, it is imposible for units to communicate with each other this way as anything i have plugged into ethernt port would not be creating a loop or extending the nwtork in anyway possible.
- FURRYe38Oct 04, 2018Guru - Experienced User
I would do as BullyTerrier did:
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
For wired back haul:
Set up IP address reservations for each satellite and devices on the router as you add them to the router. The satellites need to be set up via wireless first. Then connect 1 satellite at a time to the ethernet LAN cable. Wait 5 minutes and the top led on the satellite should turn on BLUE. Set up an IP address reservation for the 1st satellite. Continue to do the same thing for the 2nd satellite. Then follow up with your devices.
Can you reset the satellite by pressing the reset button on the satellite and wait for the top led to turn on amber, then let go. Then led should blink WHITE, then slowly pulsate WHITE? If you can get to this, this means the satellite can be re-added to the Router...Get it added wirelessly first, then if thats works, then connect a wired PC to the satellite and update manually then factory reset it once more and re-add it.
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-Satellite
I tried resetting just now. Managed to get the sateltile to reconnect. But after awhile, anything connected to the satelite would have no internet access. I will attempt the method u mentioned tomorrow, as it is night time here now and I need to rush some work. Thanks man. But seriously, I'm giving up on Netgear.
- rhett7660Oct 04, 2018Aspirant
This auto update is for the birds. I am in the same boat with over 16 devices connected to my wifi and after this last go around of having to reset everything only to lose it again. Last straw. I can't return the items, but that didn't stop me from purchasing another sytsem all together.
Try what BullyTerrier did to see if it might help you. He downloaded the update files for his system. Manually applied them, factory reset the system and set up from scratch. Seemed to have helped him.
