steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Oct 04, 2018Guru - Experienced User
Try what BullyTerrier did to see if it might help you. He downloaded the update files for his system. Manually applied them, factory reset the system and set up from scratch. Seemed to have helped him.
rhett7660 wrote:
This auto update is for the birds. I am in the same boat with over 16 devices connected to my wifi and after this last go around of having to reset everything only to lose it again. Last straw. I can't return the items, but that didn't stop me from purchasing another sytsem all together.
Ryan1919
Oct 04, 2018Tutor
Did he update the firmware first manually and then do a factory reset? Did he manually update the firmware again after the factory reset?
