steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Christian_R
Oct 12, 2018NETGEAR Employee Retired
LadySapphy - Please send me a message with your case and/or RMA number and I will have support follow up with you.
~Christian
ploo
Oct 13, 2018Guide
I posted this in a separate thread - posting it here too...
I upgraded by Orbi to 2.2.1.210 - everything seemed fine. I have a guest network (with a password) that I leave disabled and only enable when we have a guest. It is also set to not allow access to my LAN.
A few days after upgrading I noticed that my guest network was active with NO PASSWORD and it could access my LAN (the guest network has a password set). I logged into the Orbi console and it was still set to disabled, but it was broadcasting and I could connect to it with no password. The only way to turn it back off was to turn the guest network on and off again.
This is a serious security flaw! I now have major concerns about the security of this device which I've had no problems with for over a year.
Tried to roll back to previous firmware; but the Orbi just automatically updates to the latest.
Anyone else seen this guest network issue?
- FURRYe38Oct 13, 2018Guru - Experienced User
Try a factory reset and setup from scratch:
- RedBatman89Oct 15, 2018Guide
Hey I just wanted to say still that the IPV6 dropping after a few days still happens in this firmware. I have to still go in and reapply it, however now it takes a few more times before IPV6 comes back. This really needs to be fixed, IPV6 shouldn't stop after a few days.
- FURRYe38Oct 15, 2018Guru - Experienced User
