steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
TayNinh
Oct 16, 2018Aspirant
Hope someone can help me out.
I've been having wifi issue keeps dropping out on my iPad Pro 9.7" version with this router since the very beginning. I've updated my firmware everytime(currently on this fw version) there's a new one but the issue still exists. It only happens on that iPad and not on all other iPads/iPhones/PCs. It's very annoying that it drops wifi every 5-10 minutes. I reinstalled iOS and did all reset on iPad. I've read few others having the same issue but I can't find a solution. Is this a NG issue or Apple?
- ekhalilOct 16, 2018Master
I had many similar issues.
Do you have any wired devices to the Router/Satellites? Any wired Mesh Speakers (Sonos, LG Music Flow or similar)?
All my wifi dropping/disconnections issues were gone when I disconnected those wired speakers.
- TayNinhOct 16, 2018Aspirant
I have a couple of Sonos and HomePod, but they're wireless.
For wired connections I have a couple PCs, Smartthings, Hue Bridge, Printer, ObiTalk, few cameras.
Do you see any of the symptoms below:
- Frequent DHCP messages related to your iPad in question (only If you are in Router Mode)?
- The iPad shows as Wired in the Attched Devices page?
- CPU load is higher than normal in debug.htm?
If yes then try to find out which wired devices are causing loops in your system.
- FURRYe38Oct 16, 2018Guru - Experienced User
Try this:
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
- OdokOct 16, 2018AspirantThis POS firmware has bricked my orbi setup! Was all working fine on .10 firmware until this auto-update a few days back.
Have been having disconnection issues ever since. Tried factory resetting today and now I can’t access the RBR50 with “password” as my access password.
No wifi in my house. Thanks for nothing Netgear you absolute d1ckhöles- FURRYe38Oct 16, 2018Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Wait for the WHITE led to slowly pulsate, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Try this as well:
