steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Odok
Oct 16, 2018Aspirant
This POS firmware has bricked my orbi setup! Was all working fine on .10 firmware until this auto-update a few days back.
Have been having disconnection issues ever since. Tried factory resetting today and now I can’t access the RBR50 with “password” as my access password.
No wifi in my house. Thanks for nothing Netgear you absolute d1ckhöles
Oct 16, 2018Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Wait for the WHITE led to slowly pulsate, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Try this as well:
- Ryan1919Oct 16, 2018Tutor
I just want to clarify something because this confused me in the beginning. You always say hold down the reset pin until the top led light turns amber, but in my experience I just have to wait until the power light on the back turns amber for the factory reset. I’ve never seen the top led turn any color while holding down the reset pin. If I hold it down longer than 30 seconds would the top led turn amber? I usually hold down the reset pin for 30 seconds and in that time only the power light on the back blinks amber.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Try this as well:
No wifi in my house. Thanks for nothing Netgear you absolute d1ckhöles- DavenleiOct 16, 2018Guide
My RBS50 is now constantly dropping internet connectivity with this new firmware 2.2.1.210. It was rock solid on the previous firmware and I had no complaints. Suddenly my internet became flakey with everyone complaining and noticed that an auto firmware update now has installed an unstable firmware. I moved it back to the previous version but the satellite loaded the new one in again after a while.
I am getting tired of these buggy releases. They need to fire all their QA and get new people or implement a proper QA process. If our dev team put out crap like this several times as we have experienced from Netgear IT, my team would have all been fired. Why is the Product Manager and Business leaders allowing this to happen over and over?
- FURRYe38Oct 17, 2018Guru - Experienced User
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Last restort you'll need to manually load FW and try:
I've never used the led in back. I've always used the top LED as indicator for what the status is of the device. Since most of the inidication is here, this is were I look at to see what the device is doing and it's status. AMBER, then Blink WHITE(System is starting), then Pulsate WHITE(I'm Ready to sync or setup), then Pink(Processing or Not connected) then BLUE(Connect Est), then OFF(Working Correctly) if everything was set up right.
