tarxvf
Oct 08, 2018Guide
Firmware 2.2.1.210 remote management not working
Remote Management stopped working after upgrading to this firmware version, does not connect with the new app.
- Oct 19, 2018
Today i reset the Orbi and was successfully able to enable remote management. I am not sure what the problem was, but seems its gone for now. I have updated the support case with these notes also - if they need any more information from me they will reach out.
Thank you @Christian_R for your support.
Oct 08, 2018Guru - Experienced User
Has the System been powered down for 1 minute then back on?
Might try a full factory reset on the Orbi and set up from scratch to see if this helps.
