tarxvf
Oct 08, 2018Guide
Firmware 2.2.1.210 remote management not working
Remote Management stopped working after upgrading to this firmware version, does not connect with the new app.
- Oct 19, 2018
Today i reset the Orbi and was successfully able to enable remote management. I am not sure what the problem was, but seems its gone for now. I have updated the support case with these notes also - if they need any more information from me they will reach out.
Thank you @Christian_R for your support.
Ryan1919
Oct 08, 2018Tutor
Open your orbi mobile app while connected to your wifi..Go to the settings and disable remote management while still connected to your wifi..Immediately enable remote management again and see if remote management works after that. I did these steps because it would show that my system was offline while trying to connect remotely and after I did this it came back up.
tarxvf
Oct 08, 2018Guide
For now i have downgraded because my skybell stops working and i need that to function. I will try this again over the weekend and let you know.
- Ryan1919Oct 08, 2018Tutor
Sounds good..Good luck with all that.!!
- FURRYe38Oct 08, 2018Guru - Experienced User
Send the Moderator your information:
- tarxvfOct 10, 2018Guide
I tried disabling remote managemnet and then back on, it got disabled just fine, but when i tried to enable it back on it said "Some error occured while enabling/disabling remote management"
Stuck on that for now.
Thanks
- FURRYe38Oct 10, 2018Guru - Experienced User
What happens if you reboot the router then try to enable RM? Do you get same message?
Thanks
