tarxvf
Oct 08, 2018Guide
Firmware 2.2.1.210 remote management not working
Remote Management stopped working after upgrading to this firmware version, does not connect with the new app.
- Oct 19, 2018
Today i reset the Orbi and was successfully able to enable remote management. I am not sure what the problem was, but seems its gone for now. I have updated the support case with these notes also - if they need any more information from me they will reach out.
Thank you @Christian_R for your support.
tarxvf
Oct 08, 2018Guide
For now i have downgraded because my skybell stops working and i need that to function. I will try this again over the weekend and let you know.
Oct 08, 2018Guru - Experienced User
Send the Moderator your information:
- tarxvfOct 10, 2018Guide
I tried disabling remote managemnet and then back on, it got disabled just fine, but when i tried to enable it back on it said "Some error occured while enabling/disabling remote management"
Stuck on that for now.
Thanks
- FURRYe38Oct 10, 2018Guru - Experienced User
What happens if you reboot the router then try to enable RM? Do you get same message?
Thanks
After rebooting the orbi, still getting the same error.
When i downgraded it started working as earlier. This is the only issue i am dealing with for now.
