rjantigua
Jul 12, 2019Guide
Firmware 2.3.5.30 valid for RBR50/RBS50?
I see in another thread that people are upgrading their RBR50 routers to 2.3.5.30 with success. I got the prompt on the Orbi app that this version was available for upgrade and I pushed the button t...
- Jul 16, 2019
Hi rjantigua
Were you able to update the firmware to 2.3.5.30? Firmware is already posted on our support site https://kb.netgear.com/000061080/RBR50-RBS50-Firmware-Version-2-3-5-30
Blanca
Community Team
Jul 12, 2019Guru - Experienced User
Don't be confused. NG sometimes pushes FW to Orbis for users to install if they wish before posting on the support download page. The support page seems to be last that gets updated.
This version if valid for the 50 series Orbi. Its install and IS running on my RBK50 system.
Nick_Wilson
Jul 13, 2019Aspirant
I seem to be having frequent disconnects on iOS as well as Android devices. It seems to revert to using cellular which isn't right. I haven't noticed issues on other devices on my network, but since I upgraded to v2.3.5.30 on both the router and satellite I've been having these types of issues. I am debating to do a factory reset and restart with the v2.3.1.60 firmware instead and leave this one till it's been proven to be more stable.
- FURRYe38Jul 13, 2019Guru - Experienced User
Please make a new post and we'll help you out.
Try a factory reset with v30 loaded and setup form scratch. IF this still fails, post a new post and we'll make some suggestions. Or post here about your experiences with v30:
V30 is working here for me with my iPhones and Android devices using v30.
Nick_Wilson wrote:I seem to be having frequent disconnects on iOS as well as Android devices. It seems to revert to using cellular which isn't right. I haven't noticed issues on other devices on my network, but since I upgraded to v2.3.5.30 on both the router and satellite I've been having these types of issues. I am debating to do a factory reset and restart with the v2.3.1.60 firmware instead and leave this one till it's been proven to be more stable.
- Nick_WilsonJul 13, 2019Aspirant
Thanks, I factory reset with the existing firmware and will monitor for the next few days to see if the situation improves. I appreciate the quick answer!
Sounds good. Keep us posted. :smileywink:
Nick_Wilson wrote:Thanks, I factory reset with the existing firmware and will monitor for the next few days to see if the situation improves. I appreciate the quick answer!
