SkywalkerPD's avatar
SkywalkerPD
Apprentice
Sep 30, 2019
Firmware 2.5.0.36 release notes
Hi,
Just got a new firmware on my RBK50. version is 2.5.0.36. Are there any release notes for this firmware please?
  • The notes are now there, I upgraded and lost the "attached devices". Although all my devices connected succesfully after the upgrade only 7 devices showed on the list instead of the usual 20+ and 5 of them were not named correctly.
    Reverted back to previous firmware and the list is now functioning correctly. First problem I've had with the firmware, so I've never factory reset or anything. If i get a chance i might try that later (or just stay on 2.3.5.30 !)
  • I've got the same question.  Happened to go into Admin on my Orbi's and explore a little.  Clicked on firmware and it tells me 2.5.0.36 is available.  This release isn't listed on the Orbi support home page so probably not going to install it for a while.
    • SkywalkerPD's avatar
      SkywalkerPD
      Apprentice
      New Features and Enhancements:
      • Circle Parental Controls support for India.
      • Auto Time zone detection feature and setting.
      Bug Fixes:
      • The client was not able to obtain an IP address when the router rebooted or the client renewed the IP address
      • The iOS speed test uploaded the throughput issue in PPPoE mode
      • Issues with the Japanese language string
      • The user wasn’t able to log in to the GUI after finishing the GUI installation
      • The router GUI could not be accessed using oribilogin.com or orbilogin.net
      Security Fixes:
      • Fixes security issues.
    • FURRYe38's avatar
      Factory reset and setup from scratch the RBR and RBS to see if this helps resolve anything next time you update FW.
  • Just a heads up, after I done the upgrade I lost access to my dual SSID. Telnet failed to re activate it and it keeps reverting back to single SSID after a reboot.
    • FURRYe38's avatar
      Separation of SSID is not supported on any Orbi system!
