-RCM-
Jun 21, 2020Aspirant
Firmware 2.5.1.16 RBR50 Trouble
Before upgrading to version 2.5.1.16 firmware, I was on 2.5.1.8. I had no issues with devices connecting. After I upgraded to 2.5.1.16, two devices would no longer connect. Even tried deleting and setting up the connection again. I then rolled the firmware back to 2.5.1.8 and they connected right away, no problem.
If it works great, I'd leave it until the next update. Don't fix what isn't broken.
Unless you really want the update. then I'd update the firmware, factory reset, and reinstall.
Would be helpful to know what these two devices are?
- -RCM-AspirantThe two device are a Fitbit Aria scale and a Denon AV Receiver S640H.
