Haj
Feb 19, 2020Aspirant
Firmware 2.5.18 Slows Down
I updated the firmware to 2.5.1.8 on both the RBR50 and RBS50. The device map and naming functionality is nice. However, after 24 hours or so, the system slows down to about 40 Mbps on all wireless...
Feb 19, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
Has a factory reset and setup from scratch been performed after applying the v2.5.1..8 FW update?
Retired_Member
Feb 19, 2020
FURRYe38 wrote:Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Above suggestions working:
Why are my posts being removed? It was a valid question.
