altern8
Sep 01, 2018Aspirant
Firmware mismatch
This morning, i received an notification that an new firmware was available for my RBR20/RBS20 unit so I proceeded with the update. After the dust settled, I noticed the update only took place for the RBR20 unit and the RBS20 stayed on v2.1. I search the NetGear support page and was surprised to see there is no v2.2 for the RBS20 for me to download. Is this by design?
Yes. Check to see if there is a RBR match as well. There should be however if there isn't thats ok. the RBS can have the newer version. Just update the satellites first when doing FW updates.
- altern8Aspirant
Thanks for the quick reply!
Sorry, I should have elaborated on my post. The update was performed thru the Orbi iOS app (I typically do it thru the web portal but I was lazy this morning). After the update completed, I checked the firmware version and noticed only the RBR unit was updated v2.2. No problem I thought, let me go to Netgear's website to download and perform a manual update on the satellite but the latest version of firmware for RBS20 is listed as v2.1.
You might leave the RBS alone for now. If the system is working after the update. You can wait for a future update for the RBS.
