bearyoung
Oct 25, 2019Aspirant
Firmware of europe
I bought a rbk23 in US, will move to Germany soon, can I use it's newst firmware of Europe? Will I brick the orbi?
3nwq
Oct 26, 2019Aspirant
US is more restrictive on the 2.4GHz channels, not allowing the channels 12 and 13.
On 5 GHz your Orbi will default different channels that would be used in Europe.
But all those channels that are available in USA are ok to use in Europe.
So don't worry. Just use it.
CrimpOn
Oct 26, 2019Guru - Experienced User
I believe this is the post describing how to change the Region
https://community.netgear.com/t5/Orbi/ORBI-RBK53-Region-Change/m-p/1811833#M72806
- bearyoungOct 27, 2019AspirantMy concern is that I am not sure if this works on the rbk23, as you wrote, the method is for rbk53.
- CrimpOnOct 27, 2019Guru - Experienced User
bearyoung wrote:
My concern is that I am not sure if this works on the rbk23, as you wrote, the method is for rbk53.There is one quick way to find out: telnet into the router, apply the settings, and see what pops up.
The bottom choice is North America, and should already be selected. If the rest of the world is on the drop down menu, then you are "good to go". No need to actually select one of the other choices.
