HoangNa297
Mar 24, 2020Aspirant
Firmware Orbi RBK50
Which firmware is best for Netgear Orbi Rbk50? In 2017, I started using Netgear Orbi rbk50. That is my favourite firmware, but I don't remember that. The latest version( 2.5.1.8 ) the coverage is not...
Mar 25, 2020Guru - Experienced User
Try a factory reset on the RBR and RBS if you haven't tried this after loading v2.5.1.8. If this fails to fix what your seeing, then you can down grade. You can also try Voxels 3rd party FW for Orbi as well:
Suggestions to try as well:
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://community.netgear.com/t5/Orbi/Orbi-model-RBR50-keeps-dropping-connection-during-Zoom-calls/m-p/1874136/highlight/true#M84647
HoangNa297 wrote:Which firmware is best for Netgear Orbi Rbk50? In 2017, I started using Netgear Orbi rbk50. That is my favourite firmware, but I don't remember that. The latest version( 2.5.1.8 ) the coverage is not extensive; it seems that upgrading NETGEAR makes my router run slower, the throughput is very bad, it's about 200 to 300Mbps. Should I use the custom firmware or downgrade stock firmware?
