gm2t2
Dec 20, 2017Aspirant
Firmware Problems w/ Satellites
I updated the firmware on my router before I installed my satelite firmware update. It will not upadte the satelite through software or by doing it outside software. When I go to software update I get an error message "failed to get firmware version" and it stops at that point.
Could I just factory reset both router and satelite and start over or is there a better way?
That .img file looks correct.
Did you unzip the file that you downloaded or are you trying to load it from within the zipped file?
- Streak2Master
Have you tried using manual update?
Select the satellite you want to update and then upload the update that you can get from here
- gm2t2Aspirant
It says I am not connected to the internet. I am hard wired from router to computer. I can get on the internet anytime I want to setup as it is now. I am lost.
DO
- gm2t2Aspirant
After going thru the manual install, it tells me the firmware version I am trying to install is incorrect, please load correct file and try again. RBS50-V2.1..img is the file populated in the correct box.
- Streak2Master
