jvmagic
May 01, 2020Follower
Firmware update - msg - Looks like you’re not connected xxxx
Hi, I have the latest 'Xfinity' box and upgraded to 1G speeds. In my two story home I get 600-700 or os dowload speeds when I'm next to the router. The Orbi satellite is downstairs and I cannot co...
May 02, 2020Guru - Experienced User
IF the ISP modem has a built in router already, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You can get v16 FW from here if you want to manually download and install.
Install the RBS first then RBR lastly.
jvmagic wrote:Hi,
I have the latest 'Xfinity' box and upgraded to 1G speeds. In my two story home I get 600-700 or os dowload speeds when I'm next to the router. The Orbi satellite is downstairs and I cannot connect to the wifi (90 percent of the time). No wifi connection which is weird because w/out the Orbi and just the Xfinity router, I can get better wifi connection. I reset the Orbi satellite via the reset button and nothing has changed.
I was trying to update the firmware by following the orbi manual instructions but when I login to orbilogin.com it stating " Looks like you’re not connected to your Orbi’s WiFi network. Don’t worry, it happens to the best of us. Try the following steps to get connected:" No matter if I clear the browser cache etc.
So I have two problems:
Can't upgrade the firmware - current v2.3.5.26
Wifi not working on satellite - RBR20
Comcast router model - XB6-A
Thanks in advance
