rmoran52
Aug 27, 2018Tutor
Firmware Update Problem with Orbi Satellite
I am trying to update my Orbi satellite RBS50 to the latest firmware but it keeps telling me I have to incorrect version when I know I have chosen the right one. It goes through with the attempt to u...
Aug 27, 2018Guru - Experienced User
Try an intermeddiate version first then load the last recent version. I saw with with my friends system when I helped get his going:
Version I used is listed there...Try something half way in between what you have loaded now and most current available.
Did you update the router already?
You can directly connect to the back of the satellite if it's already connected to base ruoter and update directly there using the satellites IP address to log in to its UI.
- rmoran52Aug 27, 2018Tutor
Thanks Furry38, I will try your solution first. I have not updated the router as it says to update the sattelite first.
- FURRYe38Aug 27, 2018Guru - Experienced User
Ok good, ya update satellite first. It should update to something intermediate, the you can apply the last current version.
