Badger894's avatar
Badger894
Follower
Mar 25, 2020
Firmware Update RBR40 says updated but check version and still the same
Hi - I’m on FW 2.3.5.30 and trying to update to .32. I go thru process with app and it says it updated, but then when I check version in app it’s still the same and continues to tell me there’s a new version. What can I do to make sure it’s Truly updated?
  • Retired_Member's avatar
    Retired_Member
    why update?
  • FURRYe38's avatar
    You can manually download FW files from NG download site if you wish to update.
