MichelvanEunen
Jun 24, 2023Aspirant
Firmware update shows many sattellites
Helllo,
When i go to my firmware update screen it shows many many times the same sattellite RBS50. IT is in that list hundreds of times again and again. Is there someone who can explain this to me? And if this is hamrfull?
Hope someone can explain this...
Thanx a lot!
MIchel van Eunen
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Might manually update the RBS manually first then the RBR lastly:
If the recommended reboot doesn't work, you can try a simple factory reset and reinstall
