vincemiller
Oct 20, 2016Aspirant
Firmware update V1.3.0.12
Anybody else get this tonight? I just checked for an update and V1.3.0.12 showed up and downloaded. Up and running, just not sure what it did. Looks like the webpage isn't updated yet. 🤔
- Oct 20, 2016
If you click on the V1.3.0.12 link in the Firmware Update page it shows a nifty popup with the changes:
Current Version: V1.2.0.6 New Version: V1.3.0.12 Release Notes:
[New or Enhancement Feature] Supports Canada and China wireless regions.
[New or Enhancement Feature] Optimizes the 5 GHz backhaul RTS threshold to improve the wireless performance.
[New or Enhancement Feature] Supports OpenVPN.
[Bug Fixed] Fixes the issue in which some devices display as "unknown" in the Attached Devices page. [Bug Fixed] [Security Fix]Fixes the issue in which IPV6 port 80 and 443 closes by default.
[Bug Fixed] Fixes the GUI language for China.
[Bug Fixed] Fix the issue in which wireless devices display as “wired” in the Attached Devices page.
[Bug Fixed] Corrects the DNS configure issue when Parental Controls is enabled.
[Bug Fixed] Fixes the firmware auto update fail issue when multiple satellites are updated.
[Bug Fixed] Fixes the issue in which the incorrect number of connected devices are displayed.
Mikey94025
Oct 20, 2016Hero
| Current Version: | V1.2.0.6 |
| New Version: | V1.3.0.12 |
Release Notes:
- peteytestingOct 20, 2016Hero
although this isnt a massive update i suspect ( but i might be wrong ) that this fw update is in preperation for a coming further fw update in a few weeks time as you notice non of the features are included in this apart from openvpn
pete
word is that this release is so the orbi system can be released in certain countries , eg Canada and China
pete
- Yld2robOct 21, 2016Luminary
I guess they didn't fix the Dropcam disconnect issue. All my other 52 devices they are connected work fine. My 30 day return period is expiring soon. Back to Best Buy they are going to have to go until they fix that issue. I guess I willkepp updated on the firmware releases and wait for the "fix"
